Need some help on I2C with PIC16F1619
paulfjujo
France 01800
hello,
i turn around this probleme since any days
did many tests without succes ..
Impossible to get the ACK from slave device with A PIC16F1619 as Master I2C.
I am using I2C remappable from MikroC
This PIC uses PPS to map IN/OUT and fonctions
I tested the I2C Bus with a SSD1306 LCD, a RTC DS3231 and an LCD+PCF8754 .. same problem
On teh data sheet of this PIC, I2C is a bit different than classical I2C
Extra Registers and flags have been added ..
I tried also some code from Github OLED LCD .. without succes
No executable code *.Hex (correponding to the project ) is delivered, so i can't trust also with this code .
If someone successfully tested this PIC with I2C hardware, please post a copy of your *.hex and config.
here is my code
#define VERSION "2020_01_22"
   //ac:Shema_16F1619
    // ac:Pinout_16F1619
// cocher High voltage ICSP Options  MPLAB IPE et Pickit4
// Hardware 16F1619  DIP20 :
PIN 1    VDD   +5V
PIN 2    RA5
PIN 3    RA4  output --> Led Rouge ---2.2K--+5V
                    |---750--ICSP VPP  PIN 1 Pickit2
Pin 4     RA3/ MCLR |--- 6,8K --- +5V
Pin 5     RC5 ---> sortie SQA synchro ( Led Bleue )
pin 6     RC4
pin 7     RC3
pin 8     RC6
pin 9     RC7
pin 10    RB7  TX ----> UART ---> Ecran  fil Blanc Prolific USB
Pin 20    VSS  --+5V
Pin 19    RA0  --- ICSP Data
Pin 18    RA1  --- ICSP Clock
Pin 17    RA2
Pin 16    RC0  --- SPI Clck
Pin 15    RC1
pin 14    RC2
pin 13    RB4  <---> SDA I2C
pin 12    RB5  Rx  <--- UART <--- clavier fil vert  Prolific USB
pin 11    RB6  <--> SCL I2C
#define PROJECT "Test_16F1619_I2C1_Hw_2020.mcppi"
#define SOURCE "_16F1619_Test_I2C"
#define Langage "MikroC 7.6.0"
#define PROCESSOR "PIC 16F1619 "
#define DEVICES  "OLED DISPLAY IIC I2C 0.91  128x32"
#define EEPROM  "No....ihex"
#define POWER_SUPPLY  "DC_5V"
#define OSCILLATEUR_INTERNE
#define FOSC "16.0"  // MHz
#define BAUD "19200"  // UART1
#define OTHERS " "
/* config bits
CONFIG1 : $8007 : 0x38E4
CONFIG2 : $8008 : 0x1E83
CONFIG3 : $8009 : 0x3F1F
#include "built_in.h"     // for  Hi  Lo ..etc
#define CLS 12
#define CR 13
#define LF 10
#define TAB 9
#define BACK 8
#define Beep 7
#define Separator 0x20   // space
#define Byte unsigned char
#define ON 0
#define OFF 1
//#define LCD_ADDR 0x4E  //
#define Word unsigned int
//#define OLED_ADDRESS   0x78    //@ I2C sur 8 bits
//#define OLED_ADDRESS   0x3C     //@  I2C sur 7 bits
sbit Led_Rouge at LATA.B4;
sbit Led_Rouge_Dir at TRISA.B4;
sbit SQA at LATC.B5;
sbit SQA_Dir at TRISC.B5;    // avec Led_Bleue
unsigned int OLED_ADRESS=0x0078;
unsigned int addr;
int i,j,k,l,m,n;
void Init_Hardware(void) ;
void strConstRamCpy(unsigned char *dest, const code char *source);
 void Init_Hardware()
  //REGISTER 6-1: BORCON: BROWN-OUT RESET CONTROL REGISTER
  BORCON.SBOREN=0;
  // no analog on PORT A,B,C
  ANSELA=0;
  TRISA=0xFF;
  Led_Rouge_Dir=0;  // RA4
  Led_Rouge=0;
  ANSELB=0;
  TRISB=0b11111111;
   // I2C pin must be set as input and Open drain
  WPUB=0 ;// Weak pull up on port B RB4-RB7 :  0=DISABLED
  //  1=open drain    0=push pull output
  ODCONB.B4 = 1;  // 1=open drain  output   SDA
  ODCONB.B6 = 1; // 1=open drain output   SCL
  ODCONB.B5 = 0;  // 0=push pull   input  RX
  ODCONB.B7 = 0;  // 0=push pull output   TX
  SLRCONB=0xF0; // 1 = Port pin slew rate is limited
  INLVLB=0x00; //1 = ST input used for PORT reads and interrupt-on-change
  ANSELC=0;
  TRISC=0b11011111;    // RC5 output SDA et Led Bleue
  WPUC=0b00100000 ;// Weak pull up on port C RC5
  ODCONC.B5 = 1; //
  SQA_Dir=0;   //RC5        SQA  led Bleue tirée au +Vcc
  SQA=0;
  // page 230
  OPTION_REG.nWPUEN =0;  //  0= Weak pull-ups are enabled by individual WPUx latch values   1=disable WPUP
 void Init_Fosc(void)
 // internal FOSC
 bit 7 SPLLEN: Software PLL Enable bit
 bit 6-3 IRCF<3:0>: Internal Oscillator Frequency Select bits
     1111 =16 MHz HF
     1110 =8 MHz HF
     1101 =4 MHz HF
     1100 =2 MHz HF
     1011 =1 MHz HF
     1010 =500 kHz HF(1)
     1001 =250 kHz HF(1)
     1000 =125 kHz HF(1)
     0111 =500 kHz MF (default upon Reset)
     0110 =250 kHz MF
     0101 =125 kHz MF
     0100 =62.5 kHz MF
     0011 =31.25 kHz HF(1)
     0010 =31.25 kHz MF
     000x =31 kHz LF
 bit 2
 bit 1-0 SCS<1:0>: System Clock Select bits
  OSCCON=0;
 // 16 MHZ
   OSCCON.IRCF3=1;
    OSCCON.IRCF2=1;
     OSCCON.IRCF1=1;
      OSCCON.IRCF0=1;
// 1x = Internal oscillator block
   OSCCON.SCS1=1;
   OSCTUNE=0;
void I2C1_TimeoutCallback(char errorCode) {
   if (errorCode == _I2C_TIMEOUT_RD) {
     // do something if timeout is caused during read
   if (errorCode == _I2C_TIMEOUT_WR) {
     // do something if timeout is caused during write
   if (errorCode == _I2C_TIMEOUT_START) {
     // do something if timeout is caused during start
   if (errorCode == _I2C_TIMEOUT_REPEATED_START) {
     // do something if timeout is caused during repeated start
void Config_PPS(void)
    Unlock_IOLOCK();
    RC5PPS=0;
    RA4PPS=0;
   // ---------- Peripheral PIN and EUSART configuration ----------------------
    RB5PPS = 0x0D;      //  RX RB5
    RB7PPS= 0x12;       // TX RB7
    // --- I2C ----------------------
    // TABLE 13-2: AVAILABLE PORTS FOR OUTPUT BY PERIPHERAL
  //   REGISTER 13-2: RxyPPS: PIN Rxy OUTPUT SOURCE SELECTION REGISTER
  //  bit 7-5=0   bit 4-0 RxyPPS<4:0>: Pin Rxy Output Source Selection bits
    RB6PPS = 0x10; // 0b00010000; // 16 RB6->MSSP:SCL
    RB4PPS = 0x11; //0b00010001; // 17  RB4->MSSP:SDA;
  // TABLE 13-1: PPS INPUT REGISTER RESET VALUES
  // SPI and I2C clock SSPCLKPPS RB6
   SSPCLKPPS = 0x0E;   //RB6->MSSP:SCL;
   // SPI and I2C data SSPDATPPS RB4
   SSPDATPPS = 0x0C;   //RB4->MSSP:SDA;
    RC5PPS=0;
    RA4PPS=0;
  Lock_IOLOCK();
void main()
    Init_Fosc(); // internal FOSC  1111 =16 MHz HF
    Init_Hardware() ;
    Config_PPS();
   //6 x Clignotement Led Rouge (RA4)  et SQA (RC5)\r\n");
   // run once this , to check if MCU is running
    for (i=0;i<6;i++)
      Led_Rouge=ON;
      Delay_1sec();  // de visu
      Led_Rouge=OFF;
   I2C1_Remappable_Init(400000);
   I2C1_SetTimeoutCallback(10, I2C1_TimeoutCallback);// Delai entre AC/Nack et bit de STOP
   I2C_Set_Active(&I2C1_Remappable_Start, &I2C1_Remappable_Repeated_Start, &I2C1_Remappable_Rd, &I2C1_Remappable_Wr, &I2C1_Remappable_Stop, &I2C1_Remappable_Is_Idle);
   do
   SQA=1;  // synchro IKALOGIC SQA50 ANalyser
   I2C1_Remappable_Start();
   //I2C1_Remappable_Wr(0x78);// OLED SSD1306 adresse 7 bits  ou 0x78 adresse/8bits
   I2C1_Remappable_Wr(0xD0);// 0xD0 RTC adresse/8bits
   I2C1_Remappable_Wr(0x11);
   I2C1_Remappable_Stop();
    SQA=0;
    Delay_ms(1000);
   while(1);
i am using a IKALOGIC analyser on I2C bus
my results, connected to a RTC DS3231
No ACK follow the adresse
hardware
R pullup on I2C bus = 4.7K
SOLVED
problem with a "fil dupont" wire between PIC SDA pin and SDA on OLED LCD
wire cutted..
Now, i get the ACK
so the code is OK
