need some guidance about antenna desig
Pulkit Varshney
Member level 5
need some guidance about antenna design
hello, i want to check different antenna's (dipole, yagi, microstip patch, etc.) performance as a receiving element for a given power density.
But i am a newbie in the antenna design field. So can u tell me how should i approch this.
Which simulator should i use, I am a little familiar with ADS.
WimRFP
Advanced Member level 5
Netherlands
Hello Pulkit,
Part of the answer is given here: https://www.edaboard.com/threads/223156/#post950488.
When you want to understand and design antennas, you have to go a step further. The path can be (mostly copy and paste from another thread):
- knowing LCR circuits
- knowing basic field properties, material properties (E, H, B, D, potentials, etc) and their relation to lumped components.
- to have excellent understanding of transmission line theory.
- knowing how fields and radiation do originate from current segments and how the form the radiated power.
- knowing about constructive and destructive interference and radiation patterns.
- knowing behavior of structures no longer small w.r.t. wavelength (reflection, refraction, fresnel theory, image theory [in fact reflection]).
- knowing properties of existing antenna types to enable you to make a first selection.
- knowing how to use a suitable software package for your challenge.
The learning curve depends on your actual knowledge, the people around you (that can help you), available literature/books/other resources, and of course the effort you are able to put in it. You will meet some high mountains (sure), but they will turn into flat terrain.
mkonca
Full Member level 1
Cyprus
You should be more specific about "reception". Are you looking at measuring the total received power from all directions or assuming that the signal is coming from only one direction?
Pulkit Varshney
Member level 5
i am looking at total received power from all directions.
But it will depend on the antenna'a effective area whether it will respond to received power from all directions or power coming from only one direction.
jiripolivka
Santa Barbara
It is difficult to offer you an advice without knowing you exactly need. Specify the frequency, radiation pattern, directivity (gain), power handling, etc.
Pulkit Varshney
Member level 5
frequency around 900Mhz.
other things i have to vary to check which design is optimum
jiripolivka
Santa Barbara
Thank you, you are really gratuitous in giving off information!
For a 900 MHz antenna there are really MANY possibilities. Depends on more specifications you keep secret.
Try "www.L-com.com" to see commercial offer of 900 MHz antennas.
