Need SAA1070, SAA1058 datasheets
Borber
Advanced Member level 5
on third flor
saa1070
If somebody can help me with datasheets for those two chips. They are from Philips or Valvo and made in seventies or eighties.
saa1058
what these chip do (function) ?????
saa1058 datasheet
Both were used in communications equipement. First could be PLL with display driver and second a prescaller.
saa 1058
I know about the SAA1057 (Radio tuning PLL synth) but not a 1058
datasheet for saa1070
SAA1058 (ITT) Freq. Divider 1:32/33 DIL-16
This company have stock (no datasheet) GBP 7.97 ea. and show 42 in stock
http://www.mark5.com
I have listings of companies that sells the SAA1070 if you are interested.
valvo saa1059
Yes, and SAA1070 is counter+display driver.
valvo saa1058
My sources indicate that the 1070 were made both by ITT and Philips and possibly Telefunken as well
SAA1070 COMPT. DE FREQ.DRIVER POUR AFFICH.
Added after 1 hours 39 minutes:
This company claims to have both datasheets for a small view registration fee
https://www.eca.de/html/SAA/SAA1070.html
SAA1058-MBR AM/FM FREQUENCY SYNTH.16p
SAA1070 FREQ COUNTER/INTERFACE
saa1059 pdf
Hi Borber,
Here's the datasheet of the SAA1070.
I surely must have the SAA1058 too, somewhere . . . but I couldn't find it.
It isn't a real problem because it is only a :32/33 prescaler and there is a
brief description of it at page 9 of the datasheet of the SAA1070.
on1aag.
    Borber
Thanks sasha but your file is the same as above upload. Do you have SAA1058?
If this helps,here is the SAA1059 datasheet.
According to what I know, the SAA1059 is pin compatible with
the SAA1058,you can see it in page 9 of the SAA1070 datasheet.
If someone need datasheets of SAB1009,SAA1056,SAB1018 and SAB1018A ,
i upload if required.
    Borber
I need datasheet of SAB1018 (A), can you upload it?
Thanks
Martin
Please the SAA1056 one.
Thanks in advance...
What's mission of SAA1070, SAA1058?? Thanks
SAA1070 ==> Display Interface and Frequency counter for radios AM and FM (digital displaying of receive frequency).
SAA1058 or SAA1059 ==> Prescaler divide by 32/33 to use with SAA1070 for FM.
