Does anyone know how robot car can climb on wall? I saw the videos on Facebook about Robotic competition. I am highly appreciate for any explainations of resources. Thanks.
I guess on the bottom surface of robot have a stickly material. I'm not sure.
For Wall Climbing Robot, you need to use some pneumatic valves. A rubber front like in arrows to **** the air and then place their grip on the wall.
You must have seen gun arrows for children and when they shoot it those arrows just stick to the wall because of air suction. You have to design something like that.
Go to YouTube and search "watch this robot climb up walls". The robot has two fans and the tires contact the wall first. When it reaches the wall the front fan lifts the front end while the back wheels roll forward. Once vertical the fans keep the car pressed against the wall and tilt slightly forward or backwards depending on what direction you want to go.
What would be cool is if it could fly like a drone and then land upside down on the ceiling like a bug. If you could pull that off we might be seeing you on that television program.
