need rle decompression hardware code in vhdl
amritmani
Hi all,
I need a rle compressor and decompressor code in vhdl which can compress a decompress bit stream file. please help!!
Run-length encoding - Rosetta Code
Check these examples in many languages and convert it to VHDL or ....
-- rle_enc.vhd
-- Copyright (C) 2011 Kinsa
-- This program is free software; you can redistribute it and/or modify
-- it under the terms of the GNU General Public License as published by
-- the Free Software Foundation; either version 2 of the License, or (at
-- your option) any later version.
-- This program is distributed in the hope that it will be useful, but
-- WITHOUT ANY WARRANTY; without even the implied warranty of
-- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-- General Public License for more details.
-- You should have received a copy of the GNU General Public License along
-- with this program; if not, write to the Free Software Foundation, Inc.,
-- 51 Franklin St, Fifth Floor, Boston, MA 02110, USA
-- Details: sump.org: FPGA Based Logic Analyzer
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity rle_enc is
generic(
data_width : integer := 32
port(
clock : in std_logic;
raw_inp : in std_logic_vector ((data_width-1) downto 0);
rle_out : out std_logic_vector ((data_width-1) downto 0);
raw_inp_valid : in std_logic;
rle_out_valid : out std_logic;
rle_bit : out std_logic
end rle_enc;
architecture behavioral of rle_enc is
signal count, data, rle_out_i : std_logic_vector ((data_width-1) downto 0);
signal c0, c1, c2, c3, valid, rle : std_logic;
signal state : std_logic_vector(3 downto 0);
begin
-- count repeating data
process(clock)
begin
if rising_edge(clock) then
if raw_inp_valid = '1' then
if data = raw_inp then
count <= count + 1;
else
data <= raw_inp;
count <= (others => '0');
end if;
end if;
end if;
end process;
-- previous and current data is not the same; send old data
c0 <= '1' when data /= raw_inp and count = 0 else '0';
-- start of repeating data; send current data
c1 <= '1' when data = raw_inp and count = 0 else '0';
-- end of repeating data; send count
c2 <= '1' when data /= raw_inp and count /= 0 else '0';
-- count overflow; send count
c3 <= '1' when data = raw_inp and 0 = not count else '0';
-- rle_enc.vhd
library ieee;
entity rle_enc is
generic(
port(
end rle_enc;
begin
process(clock)
begin
count <= count + 1;
else
data <= raw_inp;
end if;
end if;
end if;
end process;
state <= c3 & c2 & c1 & c0;
rle_out_i <=
data when state = "0001" else
data when state = "0010" else
count when state = "0100" else
count when state = "1000" else
(others => 'X');
valid <=
'1' when state = "0001" else
'1' when state = "0010" else
'1' when state = "0100" else
'1' when state = "1000" else
'0';
rle <=
'0';
process(clock)
begin
rle_out <= rle_out_i;
rle_out_valid <= valid;
rle_bit <= rle;
else
rle_out_valid <= '0';
rle_bit <= '0';
end if;
end if;
end process;
end behavioral;
rle_out_i <=
(others => 'X');
valid <=
'0';
rle <=
'0';
process(clock)
begin
rle_bit <= rle;
else
rle_bit <= '0';
end if;
end if;
end process;
end behavioral;
DangerousPrototypes.com forum • View topic - Cleaned up VHDL code + Meta + new RLE + Timing fix
thanks! but those files are for text compression I need a encoder decoder for bit stream compression. configuration bitstream file only have 1 and 0 s. if i use those code it cant distinguish between integer 1 and binary 1.
