need Ready made PIC16F84 Serial Tx-Rx routines
Bus Master
Full Member level 3
Just behind You ;-)
pic16f84 rx tx
Hi all,
I need a ready made routines for PIC16F84 to communicate serially through RS232 port. As this PIC doen not contain a built in UART. You have to bit-bang the port pins Tx & Rx to simulate the UART.
Any body have these routines (Assembly is preffered)??
Thanks in advance for your help.
Yours,
Here is a piece of public domain code to achieve RS232 on a 16F84 PIC.
HTH
Siriocb
Consider using CCS PIC C compiler, it makes the serial communication a lot more easy
hi bus master,
though tihis is in C language, cuold be interesting fo you:
at htsoft.com you can dl a free c compiler for 16f84
at /examples you'll find a routine for bit banged rs232
hth
thomaz
