Need Pipeline Multiplier RTL
eda_wiz
Advanced Member level 2
rtl multiplier
Does anyone have a pipelined multiplier code..
pipeline rtl
Hi
Here is a bit:
1. h**p://www.doulos.com/knowhow/verilog_models/8bit_x_8bit_pipelined_multiplier/
* -> t
tnx
pipeline multiplizierer
Bonjour,
Regarder le URL suivant :
1. h**p://tima-cmp.imag.fr/~guyot/Cours/Oparithm/francais/Multip.htm
2. h**p://tima-cmp.imag.fr/~guyot/Cours/Oparithm/francais/Op_Ar2.htm
* ->t
merci
A funny French note done by systran!!:
Look at the following URL:
* ->t
thanks
pipelined multiplier rtl
hi Jim... thnks for those links...
CAn anyone just tell that whether u /anyone u know have worked on 8*8 multiplier which can be clocked at minimum 100 Mhz...
thanks
pipeline multiplier rtl
It is up to what lib you want to use. 0.13, 0.18 should be OK in 100M.
You can use DW to try in DC.
multiplier rtl
Hi patrickli,
I compiled DW multiliplier for TSMC .18 u... but delay I am getting is very high....well can u please say what speed u got for .18u and .13u DW multiplier..
be careful wizkid!
if you have acquired TSMC 0.18 from the Artisan pack, something strange is going on. I believe they have changed the absolute values for the timing of their cells.
This is the only explanation i have for some measurements of mine.
Try UMC from Artisan, it may have real values. By the way, in some text in the Artisan pack, "Condition of Terms"-style they state it in law terms --but not very clearly of course.
the_penetrator©
ok...
penetrator I have a question for u... what will be the delay difference for a same design in .35 and .18 u technology..
say in .35u if a design runs @ 100Mhz..
what speed approx I cud expect in .18 or .13 u process.
