Need Info about YI 827
Makhrus
Newbie level 2
Can anyone tell me what is YI 827 as marked up on top of its body as it can be seen on the attached fotograph? I found it in the Y buffer of 42 Inch Samsung Plasma TV. I heard an explosion from my TV and when I opened the TV, i just found that the suspect of the explosion was coming from this components.
bigdogguru
Administrator
Southwest, USA
The components in question appear to be SMD aluminum electrolytic capacitors 68uF 35V.
The YI827 or Y1827 is probably a lot number or date code.
The 68 is most likely the capacitance in microfarads (uF), 68uF is a common value.
The 35 is most likely the voltage rating, 35 volts is a common voltage rating.
The K is probably a device series or temperature rating, you would need to know the manufacture or possess the datasheet for those details.
The black stripe indicates the side of the negative terminal, these are polarized devices and must be installed the correct direction.
BigDog
