Need info about designing clock dividers
badola
Member level 5
bangalore
do anyone of u have clock divider circuits design manual.???? can u send me books or link from where i can get this?????:D:D:D
Re: clock dividers
this shall be useful for u
Re: clock dividers
T-FF will be a clock divider.
Input to T-FF is logic-1 always
Output of T-FF is always toggled w.r.t input clk.
the frequency will be half the input clk.
Thanks & Regards,
Sri.
Re: clock dividers
To divide by 2 you can simply use a toggle flop.
In other words you connect the QN output to the D input of the flop. The Q output will toggle with half the frequency of the clock you connect to the CLK port of that flop.
clock dividers
clock dividers
I think u want to knw about programmable divider?
clock dividers
this small paper from xilinx is also useful but contains designs with combinational loops.
you can also take a look at my blog, there is a question dealing with a divide by 3 circuit with 50% duty cycle (as in the above post)
the problem:
https://asicdigitaldesign.wordpress...w-question-for-logic-design-a-mini-challenge/
a solution
https://asicdigitaldesign.wordpress...cal-interview-question-the-standard-solution/
a more optimal solution:
https://asicdigitaldesign.wordpress.com/2008/01/31/ultimate-technical-interview-question-take-2/
There is another paper circulating on the web for all odd clock dividers which was very interesting but I can't find it right now.
ND.
