Need info about Daemon display
Anno
South Africa
So I want to connect over a network and run an app. The display must be shown on the client computer. I know Xserver is responsible and it can be done with ssh. But I want info on the programming behind the daemon that is responsible for forwarding the display to the client.
In short I want to code a similar system. Not using SSH.
Any help?
Re: Display Daemon
You can display things from clients on server. But you have to enable it manually at the server to listen from clients. Check the XServer configuration, its disabled by default.
