Jun 5, 2008 #1 M manjul Junior Member level 3 Joined May 16, 2008 Messages 30 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,288 Activity points 1,407 I am facing problem in my zero crossing detector circuit. I have used non -inverting OPAMP fort he zero crossing detector. I have given 5V AC at non inverting input thr. resistor. Inverting terminal ground. VCC +15 & -VCC -15V. I am getting square wave output but spike imposed in square o/p of negative cycle. Can anybody help?
Jun 5, 2008 #2 jiangxb Full Member level 3 Joined Apr 1, 2007 Messages 153 Helped 25 Reputation 50 Reaction score 4 Trophy points 1,298 Location hangzhou, china Activity points 2,075 can you provide the simulation result waveform?
Jun 5, 2008 #3 M manjul Junior Member level 3 Joined May 16, 2008 Messages 30 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,288 Activity points 1,407 find attached waveform
Jun 5, 2008 #4 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,410 Helped 14,749 Reputation 29,780 Reaction score 14,095 Trophy points 1,393 Location Bochum, Germany Activity points 298,054 The error is apparenly caused by the input voltage exceeding OP common mode range. You can use e. g. two antiparallel 1N4148 or similar at the OP input to limit the input voltage.
