Virashree Patel
Newbie level 1
- Joined
- Mar 13, 2015
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 152
Hi , I am starter in HDL coding and still learning how to code in verilog. I am struggling a lot with wire and reg concepts , as I am still learning about the filp flops and basic hardware concepts.
I have attached the image what my project is about. it gives a quick explanation about what I am supposed to build.
I have pasted all my code here. I am being able to see the characters on my sevenseg display for Display 1...5 , Display 6 , 7 shows "00" .
Memory.v is the auto generated file
Memory_internal.v is the top level entity in my project
Memory_internal_tb.v is the test bench file for modelsim
Please help me out to figure out where am i going wrong and feeling totally confused! I need someone to look at my code and tell me at this point! For the project I need to provide both the modelsim simulations and the output on the DE2 board.
Thanks in advance !
Controller.v
Memory_internal.v (top level entity)
Memory_internal_tb.v(testbench)
Memory.v
Thanks in advance !
Controller.v
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 `timescale 100 ns / 1 ns module Controller (clk , ar , wren, Done_c ,R,W, Q , A , Din ); input ar , clk ; output reg Done_c ; output reg wren; input [7:0] Q ; input R , W; //wire q ; reg [7:0]counter; input [9:0] A ; wire [9:0] A_m; assign A_m = A; input [7:0] Din; wire [7:0]Din_m; assign Din_m = Din ; reg [7:0]Dout; reg [4:0] cs ; parameter [4:0] Idle = 4'h0 , WritePushed = 4'h1 , WriteWait1 = 4'h2 ,WriteWait2 = 4'h3, WriteDone = 4'h4 , ReadPushed = 4'h5 , ReadWait1 = 4'h6 ,ReadWait2 = 4'h7 , ReadDone = 4'h7 , ReadWait3 = 4'h8 , Default = 4'h9; Memory ram ( .clock(clk) , .rdaddress(A_m) , .wraddress(A_m) , .wren(W) , .q(Q) , .data(Din_m)); always @ (posedge clk or negedge ar) if(~ar) cs = Idle; else begin case(cs) Idle: begin if(R == 1) cs = ReadPushed; else if(W == 1)begin wren = W; cs = WritePushed;end else begin cs = Idle ; Done_c = 0;end counter = 0; end //write: WritePushed: begin if(wren == 1) begin Done_c = 0; counter = 0; cs = WriteWait1; end end WriteWait1:begin counter = counter + 1; if(counter == 2) cs = WriteDone; else cs = WriteWait1; end WriteDone: begin counter = 0; Done_c = 1; cs = Idle; end //read ReadPushed: begin if(R == 1)begin counter = 0; cs = ReadWait1;end end ReadWait1:begin counter = counter + 1; if(counter == 100) cs = ReadDone; else cs = ReadWait1; end ReadDone: begin counter = 0; //Q = q; //Dout = Q; Done_c = 1'b1; cs = Idle ; end Default: begin counter = 0; cs = Idle ; end endcase end endmodule
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 `timescale 100 ns / 1 ns module Memory_internal (clk , ar , A_dip , D_dip , LEDgreen , WritePush , ReadPush , Display1 , Display2 , Display3 , Display4 , Display5 ,Display6 ,Display7, LEDred , TestPush , R_enable , W_enable ); input clk , ar; wire Done ; input [9:0] A_dip ; input [7:0] D_dip ; input ReadPush , WritePush , TestPush; //wire [9:0] AddressGen; //wire [7:0] DataGen; wire [7:0]Dout_wire ; output reg [6:0] Display1 , Display2 , Display3 ,Display4 , Display5 , Display6 ,Display7; output reg LEDgreen , LEDred; output reg R_enable , W_enable ; assign R = R_enable ; assign W = W_enable; reg ReadPush_prev , WritePush_prev , TestPush_prev; reg [7:0]counter; reg [9:0] A; wire [3:0]A1 , A2 ,A3; assign A1 = {2'b00 , A[9:8]}; assign A2 = A[7:4]; assign A3 = A[3:0]; reg [7:0]Din; wire [3:0] D1 , D2; assign D1 = Din[7:4]; assign D2 = Din[3:0]; reg [7:0]Data; wire [3:0] Data1 , Data2 ; assign Data1 = Dout_wire[7:4]; assign Data2 = Dout_wire[3:0]; wire [6:0]A1Display , A2Display , A3Display, D1Display , D2Display , Dout1Display ,Dout2Display ; reg [4:0]cs; parameter [4:0] Idle = 5'h0 , WritePushed = 5'h1 , WriteWait2 = 5'h3 ,WriteWait1 = 5'h4 , WriteDone = 5'h5 , Default = 5'h6, ReadPushed = 5'h7, ReadWait1 = 5'h8,ReadWait2 = 5'h9 , DoneRead = 5'hA , Idle_read = 5'hB , Push = 5'hC , DoneWrite = 5'hD, Auto = 5'hE ,Delay = 5'hF , TestPushed = 5'h10 , AutoRead = 5'h11 , AutoWrite = 5'h12 , Delay1 = 5'h13 , Delay2 = 5'h14 ; SevenSeg decoder1(.Input(D1) , .Display(D1Display)); SevenSeg decoder2(.Input(D2) , .Display(D2Display)); SevenSeg decoder3(.Input(A1) , .Display(A1Display)); SevenSeg decoder4(.Input(A2) , .Display(A2Display)); SevenSeg decoder5(.Input(A3) , .Display(A3Display)); SevenSeg decoder6(.Input(Data1) , .Display(Dout1Display)); SevenSeg decoder7(.Input(Data2) , .Display(Dout2Display)); //LFSR lfsr (.clk(clk) , .ar(ar) ,.AddressGen(AddressGen) , .DataGen(DataGen)); Controller readwrite (.clk(clk) , .ar(ar) , .R(R) , .W(W) , .Done_c(Done) , .Q(Dout_wire) , .A(A) , .Din(Din) ); //==============================================================// always@(negedge ar or posedge clk) begin if(~ar) ReadPush_prev = 1'b0; else ReadPush_prev = ReadPush; end always @(negedge ar or posedge clk) begin if(~ar) WritePush_prev = 1'b0; else WritePush_prev = WritePush; end always@(negedge ar or posedge clk) begin if(~ar) TestPush_prev = 1'b0; else TestPush_prev = TestPush ; end always@(negedge ar or posedge clk) if(~ar) begin cs = Idle; LEDgreen = 1'b0; LEDred = 1'b0; Display1 = 7'b1000000; Display2 = 7'b1000000; Display3 = 7'b1000000; Display4 = 7'b1000000; Display5 = 7'b1000000; Display6 =7'b1000000; Display7 = 7'b1000000; end else begin case(cs) Idle: begin if(ReadPush == 1'b0 && ReadPush_prev == 1'b1 && TestPush == 1'b1 )begin cs = ReadPushed; R_enable =1 ;end else if (WritePush == 1'b0 && WritePush_prev == 1'b1 && TestPush == 1'b1)begin cs = WritePushed; W_enable = 1; LEDgreen = 1'b0; LEDred = 1'b0;end else if(TestPush == 1'b0 && TestPush_prev == 1'b1)begin cs = Auto ; end else begin cs = Idle; R_enable = 0; W_enable = 0; counter = 0; end end //Read: ReadPushed: begin if(R_enable == 1) A = A_dip; Display1 = A1Display; Display2 = A2Display; Display3 = A3Display; counter = 0; cs = ReadWait1; end ReadWait1:begin counter = counter + 1; if(counter == 2) cs = DoneRead; else cs = ReadWait1; end DoneRead: begin if(Done == 1) begin R_enable = 0; Data = Dout_wire; counter = 0; Display6 = 7'b0011001;//Dout1Display; Display7 = 7'b0011001;//Dout2Display; cs = Idle ; end // else LEDred = 1'b1; end //Write WritePushed:begin if(W_enable == 1) begin LEDgreen = 1'b0; LEDred = 1'b0; A= A_dip; Display1 = A1Display ; Display2 = A2Display; Display3 = A3Display; Din = D_dip; Display4 = D1Display; Display5 = D2Display; counter = 0; cs = DoneWrite; end end DoneWrite: begin if(Done == 1) begin W_enable = 0; LEDgreen = 1'b1; LEDred = 1'b0; cs = Idle; end else if (Done == 0)begin LEDgreen = 1'b0; LEDred = 1'b1; cs = WriteWait1;end else cs = WriteWait1; end WriteWait1:begin counter = counter + 1; LEDgreen = 1'b0; LEDred = 1'b1; if(counter == 2) cs = DoneWrite; else cs = WriteWait1; end Default: cs = Idle ; endcase end endmodule //======================================================// module SevenSeg(Input,Display); input [3:0] Input; output [6:0] Display; reg [6:0] Display; always@(Input) //gfedcba case (Input) 4'h0 : Display = 7'b1000000; 4'h1 : Display = 7'b1111001; 4'h2 : Display = 7'b0100100; 4'h3 : Display = 7'b0110000; 4'h4 : Display = 7'b0011001; 4'h5 : Display = 7'b0010010; 4'h6 : Display = 7'b0000010; 4'h7 : Display = 7'b1111000; 4'h8 : Display = 7'b0000000; 4'h9 : Display = 7'b0010000; 4'hA : Display = 7'b0001000; 4'hb : Display = 7'b0000011; 4'hC : Display = 7'b1000110; 4'hd : Display = 7'b0100001; 4'hE : Display = 7'b0000110; 4'hF : Display = 7'b0001110; default : Display = 7'bx ; endcase endmodule //============================================//
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 `timescale 1 ns / 1 ns module Memory_internal_tb; reg clock ; reg reset ; reg [9:0]A ; reg [7:0]D ; wire Read_enable , Write_enable ; reg ReadPush , WritePush , ReadPush_prev , WritePush_prev , TestPush , TestPush_prev; wire [7:0]Dout; wire LEDgreen; wire LEDred; wire Done; //parameter bit_period = 104166; wire [6:0]Display1 , Display2 , Display3 , Display4 , Display5 , Display6 , Display7; Memory_internal memory (.clk(clock) , .ar(reset) , .A_dip(A) , .D_dip(D) , .LEDgreen(LEDgreen) , .WritePush(WritePush), .ReadPush(ReadPush) , .Display1(Display1) , .Display2(Display2) , .Display3(Display3) , .Display4(Display4) , .Display5(Display5) ,.Display6(Display6) ,.Display7(Display7), .Dout(Dout), .R_enable(Read_enable) , .W_enable(Write_enable),.LEDred(LEDred)); initial begin // set to 0 so toggling can occur clock = 1'b0; reset = 1'b1; // Start reset at 1 #1 reset = 1'b0; // Set reset to 0 after 5 ns #20 reset = 1'b1; // Set reset to 1 // Generates the input values #10 ReadPush = 1'b0 ; ReadPush_prev = 1'b1; //Read_enable = 1'b1; #2 A = 10'h123; @(posedge clock) #2 ReadPush = 1'b1; @(posedge clock) #20 WritePush = 1'b0 ; WritePush_prev = 1'b1; //Write_enable = 1'b1; #2 A = 10'h101; D = 8'h20; @(posedge clock) #2 WritePush = 1'b1; @(posedge clock) #10 TestPush = 1'b0; TestPush_prev = 1'b1; end // Controls the test clock always #12 clock = ~clock; // For 12 ns period endmodule
Memory.v
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 // megafunction wizard: %RAM: 2-PORT% // GENERATION: STANDARD // VERSION: WM1.0 // MODULE: altsyncram // ============================================================ // File Name: Memory.v // Megafunction Name(s): // altsyncram // // Simulation Library Files(s): // altera_mf // ============================================================ // ************************************************************ // THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE! // // 13.0.1 Build 232 06/12/2013 SP 1 SJ Web Edition // ************************************************************ //Copyright (C) 1991-2013 Altera Corporation //Your use of Altera Corporation's design tools, logic functions //and other software and tools, and its AMPP partner logic //functions, and any output files from any of the foregoing //(including device programming or simulation files), and any //associated documentation or information are expressly subject //to the terms and conditions of the Altera Program License //Subscription Agreement, Altera MegaCore Function License //Agreement, or other applicable license agreement, including, //without limitation, that your use is for the sole purpose of //programming logic devices manufactured by Altera and sold by //Altera or its authorized distributors. Please refer to the //applicable agreement for further details. // synopsys translate_off `timescale 1 ps / 1 ps // synopsys translate_on module Memory ( clock, data, rdaddress, wraddress, wren, q); input clock; input [15:0] data; input [9:0] rdaddress; input [9:0] wraddress; input wren; output [15:0] q; `ifndef ALTERA_RESERVED_QIS // synopsys translate_off `endif tri1 clock; tri0 wren; `ifndef ALTERA_RESERVED_QIS // synopsys translate_on `endif wire [15:0] sub_wire0; wire [15:0] q = sub_wire0[15:0]; altsyncram altsyncram_component ( .address_a (wraddress), .clock0 (clock), .data_a (data), .wren_a (wren), .address_b (rdaddress), .q_b (sub_wire0), .aclr0 (1'b0), .aclr1 (1'b0), .addressstall_a (1'b0), .addressstall_b (1'b0), .byteena_a (1'b1), .byteena_b (1'b1), .clock1 (1'b1), .clocken0 (1'b1), .clocken1 (1'b1), .clocken2 (1'b1), .clocken3 (1'b1), .data_b ({16{1'b1}}), .eccstatus (), .q_a (), .rden_a (1'b1), .rden_b (1'b1), .wren_b (1'b0)); defparam altsyncram_component.address_reg_b = "CLOCK0", altsyncram_component.clock_enable_input_a = "BYPASS", altsyncram_component.clock_enable_input_b = "BYPASS", altsyncram_component.clock_enable_output_a = "BYPASS", altsyncram_component.clock_enable_output_b = "BYPASS", altsyncram_component.intended_device_family = "Cyclone II", altsyncram_component.lpm_type = "altsyncram", altsyncram_component.numwords_a = 128, altsyncram_component.numwords_b = 128, altsyncram_component.operation_mode = "DUAL_PORT", altsyncram_component.outdata_aclr_b = "NONE", altsyncram_component.outdata_reg_b = "CLOCK0", altsyncram_component.power_up_uninitialized = "FALSE", altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE", altsyncram_component.widthad_a = 7, altsyncram_component.widthad_b = 7, altsyncram_component.width_a = 16, altsyncram_component.width_b = 16, altsyncram_component.width_byteena_a = 1; endmodule // ============================================================ // CNX file retrieval info // ============================================================ // Retrieval info: PRIVATE: ADDRESSSTALL_A NUMERIC "0" // Retrieval info: PRIVATE: ADDRESSSTALL_B NUMERIC "0" // Retrieval info: PRIVATE: BYTEENA_ACLR_A NUMERIC "0" // Retrieval info: PRIVATE: BYTEENA_ACLR_B NUMERIC "0" // Retrieval info: PRIVATE: BYTE_ENABLE_A NUMERIC "0" // Retrieval info: PRIVATE: BYTE_ENABLE_B NUMERIC "0" // Retrieval info: PRIVATE: BYTE_SIZE NUMERIC "8" // Retrieval info: PRIVATE: BlankMemory NUMERIC "1" // Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_A NUMERIC "0" // Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_B NUMERIC "0" // Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_A NUMERIC "0" // Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_B NUMERIC "0" // Retrieval info: PRIVATE: CLRdata NUMERIC "0" // Retrieval info: PRIVATE: CLRq NUMERIC "0" // Retrieval info: PRIVATE: CLRrdaddress NUMERIC "0" // Retrieval info: PRIVATE: CLRrren NUMERIC "0" // Retrieval info: PRIVATE: CLRwraddress NUMERIC "0" // Retrieval info: PRIVATE: CLRwren NUMERIC "0" // Retrieval info: PRIVATE: Clock NUMERIC "0" // Retrieval info: PRIVATE: Clock_A NUMERIC "0" // Retrieval info: PRIVATE: Clock_B NUMERIC "0" // Retrieval info: PRIVATE: IMPLEMENT_IN_LES NUMERIC "0" // Retrieval info: PRIVATE: INDATA_ACLR_B NUMERIC "0" // Retrieval info: PRIVATE: INDATA_REG_B NUMERIC "0" // Retrieval info: PRIVATE: INIT_FILE_LAYOUT STRING "PORT_B" // Retrieval info: PRIVATE: INIT_TO_SIM_X NUMERIC "0" // Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone II" // Retrieval info: PRIVATE: JTAG_ENABLED NUMERIC "0" // Retrieval info: PRIVATE: JTAG_ID STRING "NONE" // Retrieval info: PRIVATE: MAXIMUM_DEPTH NUMERIC "0" // Retrieval info: PRIVATE: MEMSIZE NUMERIC "2048" // Retrieval info: PRIVATE: MEM_IN_BITS NUMERIC "0" // Retrieval info: PRIVATE: MIFfilename STRING "" // Retrieval info: PRIVATE: OPERATION_MODE NUMERIC "2" // Retrieval info: PRIVATE: OUTDATA_ACLR_B NUMERIC "0" // Retrieval info: PRIVATE: OUTDATA_REG_B NUMERIC "1" // Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0" // Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_MIXED_PORTS NUMERIC "2" // Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_A NUMERIC "3" // Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_B NUMERIC "3" // Retrieval info: PRIVATE: REGdata NUMERIC "1" // Retrieval info: PRIVATE: REGq NUMERIC "1" // Retrieval info: PRIVATE: REGrdaddress NUMERIC "1" // Retrieval info: PRIVATE: REGrren NUMERIC "1" // Retrieval info: PRIVATE: REGwraddress NUMERIC "1" // Retrieval info: PRIVATE: REGwren NUMERIC "1" // Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0" // Retrieval info: PRIVATE: USE_DIFF_CLKEN NUMERIC "0" // Retrieval info: PRIVATE: UseDPRAM NUMERIC "1" // Retrieval info: PRIVATE: VarWidth NUMERIC "0" // Retrieval info: PRIVATE: WIDTH_READ_A NUMERIC "16" // Retrieval info: PRIVATE: WIDTH_READ_B NUMERIC "16" // Retrieval info: PRIVATE: WIDTH_WRITE_A NUMERIC "16" // Retrieval info: PRIVATE: WIDTH_WRITE_B NUMERIC "16" // Retrieval info: PRIVATE: WRADDR_ACLR_B NUMERIC "0" // Retrieval info: PRIVATE: WRADDR_REG_B NUMERIC "0" // Retrieval info: PRIVATE: WRCTRL_ACLR_B NUMERIC "0" // Retrieval info: PRIVATE: enable NUMERIC "0" // Retrieval info: PRIVATE: rden NUMERIC "0" // Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all // Retrieval info: CONSTANT: ADDRESS_REG_B STRING "CLOCK0" // Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_A STRING "BYPASS" // Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_B STRING "BYPASS" // Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_A STRING "BYPASS" // Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_B STRING "BYPASS" // Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone II" // Retrieval info: CONSTANT: LPM_TYPE STRING "altsyncram" // Retrieval info: CONSTANT: NUMWORDS_A NUMERIC "128" // Retrieval info: CONSTANT: NUMWORDS_B NUMERIC "128" // Retrieval info: CONSTANT: OPERATION_MODE STRING "DUAL_PORT" // Retrieval info: CONSTANT: OUTDATA_ACLR_B STRING "NONE" // Retrieval info: CONSTANT: OUTDATA_REG_B STRING "CLOCK0" // Retrieval info: CONSTANT: POWER_UP_UNINITIALIZED STRING "FALSE" // Retrieval info: CONSTANT: READ_DURING_WRITE_MODE_MIXED_PORTS STRING "DONT_CARE" // Retrieval info: CONSTANT: WIDTHAD_A NUMERIC "7" // Retrieval info: CONSTANT: WIDTHAD_B NUMERIC "7" // Retrieval info: CONSTANT: WIDTH_A NUMERIC "16" // Retrieval info: CONSTANT: WIDTH_B NUMERIC "16" // Retrieval info: CONSTANT: WIDTH_BYTEENA_A NUMERIC "1" // Retrieval info: USED_PORT: clock 0 0 0 0 INPUT VCC "clock" // Retrieval info: USED_PORT: data 0 0 16 0 INPUT NODEFVAL "data[15..0]" // Retrieval info: USED_PORT: q 0 0 16 0 OUTPUT NODEFVAL "q[15..0]" // Retrieval info: USED_PORT: rdaddress 0 0 7 0 INPUT NODEFVAL "rdaddress[6..0]" // Retrieval info: USED_PORT: wraddress 0 0 7 0 INPUT NODEFVAL "wraddress[6..0]" // Retrieval info: USED_PORT: wren 0 0 0 0 INPUT GND "wren" // Retrieval info: CONNECT: @address_a 0 0 7 0 wraddress 0 0 7 0 // Retrieval info: CONNECT: @address_b 0 0 7 0 rdaddress 0 0 7 0 // Retrieval info: CONNECT: @clock0 0 0 0 0 clock 0 0 0 0 // Retrieval info: CONNECT: @data_a 0 0 16 0 data 0 0 16 0 // Retrieval info: CONNECT: @wren_a 0 0 0 0 wren 0 0 0 0 // Retrieval info: CONNECT: q 0 0 16 0 @q_b 0 0 16 0 // Retrieval info: GEN_FILE: TYPE_NORMAL Memory.v TRUE // Retrieval info: GEN_FILE: TYPE_NORMAL Memory.inc FALSE // Retrieval info: GEN_FILE: TYPE_NORMAL Memory.cmp FALSE // Retrieval info: GEN_FILE: TYPE_NORMAL Memory.bsf FALSE // Retrieval info: GEN_FILE: TYPE_NORMAL Memory_inst.v FALSE // Retrieval info: GEN_FILE: TYPE_NORMAL Memory_bb.v TRUE // Retrieval info: LIB_FILE: altera_mf
