Need help with simulink and circuit
dave9000
Full Member level 2
You can not directly draw a schematic in simulink - for that you need SimScape.
But you can represent the differential equation of the circuit.
Start from the higher order derivative, in this case di/dt from the inductor equation.
Then integrate it in order to get i.
Then "close the loop" using adders, gain block, and so on until you get di/dt from the other elements.
dadili
Junior Member level 2
that seems complicated o_O
dave9000
Full Member level 2
It is complicated to do with only the basic Simulink libraries.
Check in the Simulink library browser if you have the Simscape libraries installed.
Under "foundation library - electrical" you should find everything you need.
moj1001
IRAN
hi my friends
use simpowersystems library.
