ltsharma
- Joined
- May 26, 2013
- Messages
- 110
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,306
- Location
- banglore
- Activity points
- 2,003
I did a motorbike RPM meter using PIC16F628A (20MHz crystal),
Everything is perfect in Proteus, On PCB its not giving output,
Details:
Connected LEDs for showing RPM
Used T0CKI as pulse counter, and pulled down using 10K, (flow : Signal--> npn transistor --> schmitt trigger (7414) --> RA4/T0CKI/CMP2 pin,)
used 20MHz crystal and 33pf Cap's
Power source is Transformer(12-0-12)--> rectifier & 2200uf cap --> 7805 (100nf on both side) --> MCU
MCLR -->10K-->vcc || -->100nf-->Ground || Reverse diode --> Vcc
problem:
I did it in Breadboard its kind of working after putting pulldown resistor to RA4/T0CKI/CMP2 pin,
Some times works when i touch circuit,
When i place MCU on pcb its not working, all LEDs left ON even i dint connect anything to RA4/T0CKI/CMP2 pin,
Please help me, i cant recognized what is the problem,, THANK YOU
Details:
problem:
