Need help with ps/2 keyboard interface
siddharthakala
Member level 2
bangalore
I am trying to design a simple PS/2 keyboard interface for Nexys3 board. The design should just recognize some scancodes and turn on an LED and another LED to show connection of keyboard with FPGA.
My design is not working and what I dont understand is - why a PIC microcontroller is provided? Can I not just directly use the keyboard data and clock inputs without using the PIC controller for my design. I thought I should be able to implement the design on FPGA and use the PS/2 inputs directly. But its not working at all.
Nexys3 uses USB HID port for PS/2 inputs.
It would be great if someone could help me with this. Thanks a lot
lucbra
Advanced Member level 2
Belgium
try opencores - they have a ready-to-run PS/2 core (you'll need to hook the necessary interface to your LEDs of course
Good luck
srizbf
Advanced Member level 5
the PIC controller acts as a keyboard controller and sends out data and clock in ps/2 interface.
you must have the proper command to send to keyboard initially after power-on before reading the ps/2 signals.
joelby
Full Member level 4
Some of the other Digilent boards have reference designs for PS/2 that you could use - have a look at Digilent Inc. - Digital Design Engineer's Source .
The PIC provides a USB host that emulates PS/2 devices, which are much simpler to deal with than USB in an FPGA. You could connect a PS/2 keyboard or mouse directly to the FPGA (with appropriate pull-ups) if you wanted to, but Digilent figure that most people have USB peripherals these days.
siddharthakala
Member level 2
bangalore
Thanks for the helpful suggestions.
I am assuming that I will need to run the power on sequence before being able to get the codes from the keyboard. I did not see any examples or designs doing that so I thought it is not needed.
Thanks a lot
joelby
Full Member level 4
It's been a while, and I'm not sure if the NEXYS3's PS/2 emulation requires it (I have a suspicion it does, because I recall that my ATLYS doesn't generate any output when a keyboard or mouse is attached and you don't do anything else), but normally you'd send 0xFF 0xF4 to the keyboard to reset it and enable reporting.
If you look at the PS/2 design I linked in my previous post ("PS2 Mouse Control reference component"), you'll see that it does actually initialise the mouse when the controller is reset.
siddharthakala
Member level 2
bangalore
Thanks.
This is what I was doubtful about. I was not doing the reset thing before performing the required task. I think it should work now.
zafartahirov
Newbie level 3
Did u manage to connect the keyboard through USB-HID?
iaia85
Newbie level 2
Hi guys,
can I use the EPP interface to connect the usb keyboard/mouse?
