Need help with my Delay Locked Loop (DLL) design.
spec07
Junior Member level 2
I need help with my DLL design which consist of a phase detector, charge pump loop filter and a voltage control delay line(VCDL). The input of the phase detector is fed by 2 clocks (clock reference and output clock with is a feedback from the output of the VCDL. The problem I am facing now is that I am unable to lock the reference clk and output clk despite running the simulation for 300us. I am simulating at 1Mhz for the clock pulses.
Any help and advice would be appreciated.
Thank you.
tony_lth
Advanced Member level 5
Beijing
Maybe you should upload your design, let's check what's wrong.
leo_o2
China
Please have stability analysis before. Does it have enough phase margin?
spec07
What kind of phase margin are you referring to? Will take screen shot of the schematics and upload asap. Thanks for the prompt replies.
spec07
What is the number of delay stages for the VCDL required for the design if i were to use a current starved inverter? Which means how many current starved inverter I should have? For the 2 input clocks, clk_in which is input to the VCDL and clk_ref which is input to the phase detector, should I set a delay between them?
