mzeeshanarshad
Newbie level 2
- Joined
- Feb 10, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 18
I'm trying to connect the AD7961 (5MHz) I designed tADC to Zedboard. I got the AD7961 no-os driver module from the AD7961 example project at AD-WIKI site which has the following interface:
I designed custom IP using AXI4Stream interface and in the default code I replaced the commented line with the assignment to adc_data_reg which gets the value of adc_data_out wire from the ad7961 module.
And here's my block design:
I used the data_rd_rdy_out as a clock for the m00_axis and the fifo input. In the SDK I used the DMA to collect data in the DDR but when I check that data its not correct. Whats wrong with this design?
Could you please help me out?
Thanks.
Regards,
Shan
module AD7961
input m_clk_i, // 100 MHz Clock, used for tiing
input fast_clk_i, // Maximum 300 MHz Clock, used for serial transfer
input reset_n_i, // Reset signal, active low
input [ 3:0] en_i, // Enable pins input
input d_pos_i, // Data In, Positive Pair
input d_neg_i, // Data In, Negative Pair
input dco_pos_i, // Echoed Clock In, Positive Pair
input dco_neg_i, // Echoed Clock In, Negative Pair
output [ 3:0] en_o, // Enable pins output
output cnv_pos_o, // Convert Out, Positive Pair
output cnv_neg_o, // Convert Out, Negative Pair
output clk_pos_o, // Clock Out, Positive Pair
output clk_neg_o, // Clock Out, Negative Pair
output data_rd_rdy_o, // Signals that new data is available
output [15:0] data_o // Read Data
// Streaming output data is read from FIFO
always @( posedge M_AXIS_ACLK )
begin
if(!M_AXIS_ARESETN)
begin
stream_data_out <= 1;
end
else if (tx_en)// && M_AXIS_TSTRB[byte_index]
begin
// stream_data_out <= read_pointer + 32'b1;
stream_data_out <= adc_data_reg;
end
end
Thanks.
Regards,
Shan
