dsk635
I am using Orcad Capture for simulating my design. I have an opamp based design. I need to find out how the offset voltage of the opamp varies when there is variation in the Vth of the other transistors. Basically, I need to use a distribution, say Gaussian, for the Vth variation of all transistors in the design except for one of the input transistors of diff. amp. Each run of the analysis will then do a vth variation (model parameter variation) of this input MOS and show how the output of the opamp varies as vth of other transistors vary. I hope I have made my problem clear.
I'd appreciate any tips/help in solving this.
Thanks!
-D.
Thanks!
-D.
