need help with keypad
onik11
hello im fairly new to electronics and was looking to build a device that would insert inbetween a employee time clock and caputre keystrokes with a date and time stamp like when the employee will punch in their 4 to 6 digit badge number for this device to capture and store it for later retreival does anyone have a schematic or can point me in the right directions thanks
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
You may need a data acquisition system kind of system. Your system should have a controller and external memory, real time clock and keypad. The keypad data would be detected by the controller and the time, and the key press value are stored in the eeprom. This needs more memory if you have more employees. You can also go for RFID cards where the data is simple and same concept can be used.
onik11
ok can you point in the direction schematic or parts and books/instructions for what i asked or for the rfid and thank you for your response
ckshivaram
Hi; could you please follow this link. I have uploaded the complete project there. I cannot repost the same project details due to forum restriction
Added after 1 minutes:
Please follow this link. I have posted complete project documents here.
onik11
thank you i will keep you posted
Added after 19 minutes:
i looked at that link and downloaded the files i really didnt understand which one of those is the one i need is there a easier to understand newbiew version of the schematic
Added after 2 minutes:
