s_ghozati
Newbie level 1
29 tv picture
Picture is a bit folded from bottom (more in the midle). Vertical section of electronic circuit schematic includes an IC and a few resistors and capacitors. One potentiometer for adjusting vertical size. First I thing changing electrolit capacitors may fix the problem. No power transistor at vertical output. One electrolit capacitor is connected to IC goes to saw shape wave generator inside IC (as I can see from IC schematic). I think most likely this should be the problem capacitor. Next step would be changing IC. Any other Idea before I open back cover?
Ghozati
Ghozati
