Need help with Hand Coding in VHDL
rg350dxlover
Member level 1
Malaysia
Hi everyone.
I have problem understanding hand coding. Could anyone explain how to apply hand coding and demonstrate hand coding using VHDL?
Thanks.
Hand coding means you write the VHDL yourself rather than letting a code generate create the VHDL.
Hi everyone.
Thanks.
Did you mean "Hand-coding" or "Hard-Coding"?
Both makes a lot difference!!!....
is hard-coding like when you have a difficult problem?
No no, Like when you do some DUTs or realtime debug, you might want to freeze\drive some values as a constant though be a signal. In such cases, we usually denote the term "Hard-coding". This term is common because it simply tells your team-mate or helps identify the builds, for eg "Vendor ID-hard-coded", etc. :)
