Need Help with disco lights
DjDemon
Newbie level 2
Newbie level 2
disco lights +project
I need to create a device for turning on and off diferent lights in the way i want. It supposed to be conected to the computer with Centonics port. Can somebothy tell me how do i have to do it?
triac disco light
You can connect the port I/O by optodiac to the triac.
yes you can
you need to decode to parallel data your sending
and use this to gate a triac array
if you type into google search strings like
light sequencer projects
or light chasser projects or addd also the work programmable
youll have much sucess in finding exactly what you need
as free ware apps some cpu controlled by rs232 etc also
this is easy to do anyway
using a simple pic16F 84 and some code and triacs and driver transistors to switch the triacs
{although this wont easily give you a brigness per bulb}
however if you use trick of the eye
and multiplex the output
using a matrix
1 2 3 4
1BBBBB
2BBBBB
3BBBBB
4BBBBB
the B = ---bulb
you can do this simple project by
driving some i/o on the B port of the micro pic 84
and use port A to talk to computer
using rs 232
choose a sutible baud rate 0 - 115Kbps
with 9600 a usuall rate for good support this type of project
use pic basic pro or another basic pic assebler
free ones are good like picbasic lite,,,,,
and may spur you on to buy or find the full version....
but in looking at it it has enough to do this in way of assembler features
and also a good simple cheep supported and working solution {also legal} use simple com 2 connection {or com1 9600 1 stp 1 strt 0 parity 8 bit word }
