Need help with an IC in Eagle!
daryl
Newbie level 2
Eagle Help
hi guys, i need a IC ( Op Amp 741 ) but this circuit cant be obtain through the eagle, so is there any solution for this ?
Re: Eagle Help
Well, can't exactly figure out what you mean to say.
If you do not have component in library, you have to create it, or use any other opamp with same ping configuration.
I hope this answers your question.
Good Luck
Re: Eagle Help
Take a look at this library: "linear.lbr". Two packages, DIL08 and SO08 are included. Device name is "*741"
Mik
