aviator91
Newbie level 5
aviator91 led
Hi all,
I’m fairly new to electronics but I do have the basics ..... and I was wondering if I could get some help from you guys?
I need to control 3 LED’s (torch / flash light) with 1 NO momentary push button switch.
I saw a circuit / project on a web site using a 4017 Decade Counter which closely resembled what I was looking for, however I don’t have the expertise to reconstruct the circuit to suit my application. **broken link removed**
The result I’m after is;
1st push of the switch should light 2 LED’s together
2nd push of the switch should light 3rd LED on its own
3rd push all OFF
I’m using 3 x AAA batteries, and 3 x 16000mcd WHITE LEDs
Is the 4017 counter the right IC for my application? I've seen some switch IC's (ADG719 or MAX4714) can something be designed to give similar results to my Flashlight project ??
Thank you in advance,
Hi all,
3rd push all OFF
