thpthial
Newbie level 3
I am new here, and hope that someone can help with my question, it is driving me nuts.
I am currently working on a temperature controller that will have many sensors in it. [all passive components, no pic here ]
These sensors have resistor programmable hi and low trip points. I am trying to set 4 of these chips only using two pots (I would need 8 in total – and I am very limited on space). I have my circuit working using just one chip and two pots. My problem now is that I cannot detach the pots, because obviously this changes the resistance. for that trip point.
the chips are sensitive to 0 - 250kΩ
Can anyone think of anything I can use to 'lock' the resistance, or I suppose the voltage/current whilst I detach the pot and then attach it to something else. I guess it would be like a voltage or amp variable resistor, where pins 1 and 3 are the + - and pin 2 sets the resistance via current/amps/volts.
I did think of this problem before I started this project, but I am sure that I saw a 3 pinned chip that would do this, but I have lost the link for it.
the solution doesnt have to be that elegant but it would be really handy if I could do this with passive components.
I am thinking I am going to have to do somekinda funky feedback thing - I am quite new to electroincs so please go easy on me.
Thanks for reading this far, and any advice is appreciated.
cheers,
th.
cheers,
th.
