This opamp seems to have a MOS input stage.
If that's the case, the current at the input is simply the current used to charge/discharge the input capacitance of the opamp. The amplitude depends on the input capacitance, your input frequency and the source impedance as seen from the inputs. It seems conformant with specs, which state <0.1uA, which really isnt that much.
You should do some calculations to see if this 0.1uA is really the major source of any "errors" you are seeing.
