I need a name or part no of a male contact pin (not connector). Female connector part no is DIN 43650A or ISO 4400 or EN 175301-803. These female connector is used in pressure transducer and electro valves. I need to order from digikey or mouser. pls help me to find part no of male contact. i added image of the male contact. https://imgur.com/a/zb5gU
Your photo has a small solderable metal lug or tab next to the obvious large plastic piece. Are you looking for a quantity of the small metal lugs? A likely brand would be Molex.
Or, are you looking for a single flat piece which has 4 of the small metal lugs mounted on it? And the 4 lugs mate with 4 slots labelled 1,2,3,4 in the large plastic piece?
I need only that solderable metal lug(Not single flat piece). I searched molex but couldn't find exact part any of it. It has a small curve on both edge and not full flat. let me know if you know the part no of it.
