Mar 25, 2019 #1 M Marwa174 Newbie level 1 Joined Mar 25, 2019 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 9 Hi, I am required to design the power circuit of switched mode power supply with feedback its characteristic: high efficiency , low level of noise this power supply will use with doppler device can you help me to get this power supply circuit
Mar 26, 2019 #2 E Easy peasy Advanced Member level 6 Joined Aug 15, 2015 Messages 4,747 Helped 1,402 Reputation 2,804 Reaction score 1,933 Trophy points 1,393 Location Melbourne Activity points 26,228 What input? what output ? how high efficiency? what level of noise? your question is too open ended ...
Apr 7, 2019 #3 T treez Guest You suggest low level of noise.....so make sure you do good pcb layout, as in the attached Attachments Basics of SMPS Layout _4.doc 645.5 KB · Views: 73
Apr 7, 2019 #4 A Akanimo Advanced Member level 3 Joined Aug 30, 2016 Messages 848 Helped 145 Reputation 290 Reaction score 165 Trophy points 1,323 Activity points 7,125 Which specific smps are you interested in? You need to give all necessary information to get guidance. Last edited: Apr 7, 2019
