Need help to design digital level sensor circuit
Abdurazzaq
Newbie level 3
Dear all
I want help how to design digital level sensor circuit
Any suggestions or help will be appreciated
Thank you
scanman
Member level 5
Canada
Do you mean actual level of a digital signal or a process level like amount of water in a tank?
scanman
Member level 5
Canada
This depends on the type of measurement:
Liquid level
Pressure
Temperature
Are the measurements in discreet steps like upper limit / lower limit
or
Defined range like 0 - 100Kpa or 0 -10cm Hg with infinite number of steps (analog) or 2n steps (digital) ?
pranam77
Advanced Member level 5
INDIA
GrandAlf
Advanced Member level 2
UK
There are liquid pressure sensors available that give industry standard 4-20ma output. Probably the best long term reliability, they would require calibrating to compensate for the shape of the tank, probably a lookup table if irregular size.
JohnRocks
Member level 1
Hi dears,
Which one do you want to design??
Ultrasonic
Liquid level sensor…?
Flow
Temperature
Pressure…
Ultrasonic is of low cost with high performance you would like to. The liquid sensor has a compact and solid state design. You will need the LR series for measurement purposes and all the stainless steel and pushbutton setup.
Thanks
prady019
Junior Member level 3
India
Hi
Designing digital-cricket with micro-controller is much more easier then in any suggestion u can get.
