houly
Hello all,
I would have your opinion for a sensor application :
I would want to reduce the noise and also reduce the EMI effects
The sensor is deported from the PCB (about 20mm) for each connection. I’m wondering what is the best solution to protect the stage from EMI and noise ? a ring guard maybe ? a GND ring guard or a –5V ? Does the –5V reference should have a plane to reduce the impedance ?
For connection I would want to use insulated wire with shield is connected to the ground of the PCB (the other side should be unconnected) what do you think ?
here is the schematic :
