need help to correct USART coding using ATMEGA32...transmit data
hanukaran
Junior Member level 2
can anyone help me to correct this coding so that i can send the data to PC through rs232...pls..Im doing project traffic light.
#include <mega32.h>
#include <delay.h>
#include <stdlib.h>
#define red_1 PORTA.0
#define yellow_1 PORTA.1
#define green_1 PORTA.2
#define USBS 3
#define RXEN 4
#define TXEN 3
#define UCSZ1 2
#define UDRE 5
#define UCSZ0 1
#define RXC 7
void USART_Init(unsigned short int F_CPU_MHz, unsigned short int Baud_Rate)
F_CPU_MHz= 8 ; ---> Remove this line
Baud_Rate= 9600 ;--> Remove this line
UCSRB = 0x00; // Disable while setting baud rate
UCSRA = 0x00; // Disable USART flags
UCSRC = (1<<USBS)|(1<<UCSZ1)|(1<<UCSZ0); // 8-Bit data, 1-Bit Stop
UBRRL = ((F_CPU_MHz*1000000)/Baud_Rate/16)-1; // Set Baud Rate Lo - Asynch Normal Mode
UBRRH = 0x00; // Set Baud Rate Hi
UCSRB = (1<<RXEN)|(1<<TXEN); // Enable USART TX and RX
void Send_Byte(char data)
while ((UCSRA & (1<<UDRE)) == 0);
UDR = data;
char Receive_Byte(void)
while((UCSRA&(1<<RXC)) == 0);
return UDR;
void main(void){
USART_Init(8,9600);
PORTA=0x00;
DDRA=0xFF;
PORTB=0x00;
DDRB=0x03;
PORTC=0x00;
DDRC=0xFF;
PORTD=0x00;
DDRD=0xFF;
while (1)
red_1=0;
green_1=1;
delay_ms(1500);
green_1=0;
yellow_1=1;
delay_ms(1500);
yellow_1=0;
red_1=1;
delay_ms(1500);
while(1)
if (red_1==0)
green_1=1;
Send_Byte('G');
if(green_1==0)
yellow_1=1;
Send_Byte('Y');
if (yellow_1==0)
red_1=1;
Send_Byte('R');
The flow of program would never reach your second while(1) loop as it will be locked in the first one.
Move the contents of second while(1) loop to first one
thanks for your relpy sir..i really waiting for this answer.... is this will be like this?
#include <mega32.h>
#include <delay.h>
#include <stdlib.h>
#include <stdio.h>
#define USBS 3
#define RXEN 4
#define TXEN 3
#define UCSZ1 2
#define UDRE 5
#define UCSZ0 1
#define RXC 7
UDR = data;
return UDR;
void main(void){
USART_Init(8,9600);
PORTA=0x00;
DDRA=0xFF;
PORTB=0x00;
DDRB=0x03;
PORTC=0x00;
DDRC=0xFF;
PORTD=0x00;
DDRD=0xFF;
while (1)
red_1=0;
green_1=1;
if (red_1==0)
green_1=1;
Send_Byte('G');
delay_ms(1500);
green_1=0;
yellow_1=1;
if(green_1==0)
yellow_1=1;
Send_Byte('Y');
delay_ms(1500);
yellow_1=0;
red_1=1;
if(green_1==0)
yellow_1=1;
Send_Byte('Y');
delay_ms(1500);
Please check the value of the UBRRL are correct from the table of the datasheet of atmega32.
Because i think you must put also a value at the UBRRH.
if you using emulator stop and see the value..
Could you explain me more about it..pls
What is the problem? where did you stuck?
Look at the datasheet of atmega32 in usart section
Look at the datasheet of atmega32 in usart section[/QUOTE
The problem is...there is alot value in this datasheet ..i dnt have idea to choose which is proper value......
why cant get the character i send to virtual terminal
the program is not working in ISIS or in real board?
Beacause sometimes ISIS has bugs!!!!
What is your frequancy and set the baud register from the table.
this is my problem nw....i'm not sure what freq and baud register to set..can you help with some more explanation
what software are you using? By seeing your code i guess codevision..
If so Codevision will do this job for you.
You can simply select the baud rate and it will show the error %. It should be below 0.2 to get proper results.
BUt why I still cant get the out put in simulation
#include <mega32.h>
#include <delay.h>
#include <stdlib.h>
#include <stdio.h>
#define USBS 3
#define RXEN 4
#define TXEN 3
#define UCSZ1 2
#define UDRE 5
#define UCSZ0 1
#define RXC 7
UDR = data;
return UDR;
void main(void){
USART_Init(8,9600);
PORTA=0x00;
DDRA=0xFF;
PORTB=0x00;
DDRB=0x03;
PORTC=0x00;
DDRC=0xFF;
PORTD=0x00;
DDRD=0xFF;
while (1)
red_1=0;
green_1=1;
if (red_1==0)
green_1=1;
Send_Byte('G');
delay_ms(1500);
green_1=0;
yellow_1=1;
if(green_1==0)
yellow_1=1;
Send_Byte('Y');
delay_ms(1500);
yellow_1=0;
red_1=1;
if(green_1==0)
yellow_1=1;
Send_Byte('Y');
delay_ms(1500);
Try using 7.3728 MHz Crystal.
ya tanks..but i'm telling the truth...i dnt know wer to put this...i'm really dnt know..i try to learn using the datasheet and other sources but still blur..if you dnt mind can you help me....
