Changing port 2 and 3 inpedance to 25 ohm achieves impedance matching for the differential case. But if you measure the input impedance, as you did, you will still get a wrong result (75 ohm instead of 100 ohm before). This is because you are actually measuring port 2 and 3 input impedance for the single ended case, which can't be matched.
