hi all am new here ,,
i need a Project to do it at home but this stopwatch will work by 8052 mcu
and it has three inputs ,, reset ,set,start ,,
thx gys 4 hlp
You will use 3 switches, why didn't use only 1 switch?
Isn't it stopwatch right?
So, I think 1 switch is enough for start/stop toggle mode.
or maybe two switches, the other one used for hold the timer...
For the 8052, use its timer maybe the easiest way. For using it with nearly exact to real timer, use crystal with 10.xxxx MHz value.
for the output, LCD M1632 can be used, or if you want to, u can used scanning display for 6 seven segment displays.
i suggest you to using 12Mhz crystal for easy and make the timer run using interrupt for the exactly, or you can use RTC IC from maxim semiconductor. so you just read the data from the RTC
