need help solving this kirchoff current equation
trigoku
Newbie level 6
hi, i need help finding the voltages and currents across each resistor using mesh current and branch current/loop for this problem, please explain how you do it step by step in detail..thanks :D
I hope this helps.
    trigoku
thanks for your help, i came up with the same result as your, but unfortunately correct answer that show in the book is .8125 amp for mesh 1 and .125 amp for mesh 2, and i absolutely do not know how they get that answer..
Hi
I would dare to say your book might bee having a misprint.
    trigoku
Yes, or the problem has been reproduced incorrectly above.
    trigoku
the circuit i drew is the same as original, i guess it could be a misprint then, here the original i scanned out of the book, btw can someone do me a favor and draw this circuit in a simulator and see whats the result is, sorry i dont have a simulator to try out myself, thanks..
The said 0.0625 and 0.625 A result is correct for this circuit.
    trigoku
