Need Help Regarding Rs232?
sarmad_101
Member level 3
GERMANY
I want to send data to computer to check that remote is sending rite data or not. Need Help about RS232 programing.
how can i send data from this program to computer.
The remote is using RC5 protocol.
Please anybody help me out.
#include <18F252.h>
#use delay(clock=20000000)
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD
#use rs232(baud=9600, xmit=pin_C6, rcv=pin_C7)
int1 get_RC5(void);
#define IR_INPUT PIN_B0         // the infrared receiver has to be connected to an
                                // interrupt-pin!
#define IR_STATUS (!input(IR_INPUT))  // invert the signal from the infrared receiver
typedef struct
int8 data[2];
int8 state;
} rc5_struct;
rc5_struct rc5;
#int_EXT
EXT_isr()
   get_RC5();
int1 get_RC5(void)
   int16 tmp,t;
   int i;
   int1 inp;
   set_timer1(0);
   while(IR_STATUS==1);
   t=get_timer1();
   if ((t<400) || (t>800)) return 0;   // no RC5 code, abort decoding
   for (i=0;i<13;i++)
      inp=IR_STATUS;
      set_timer1(0);
      while (IR_STATUS==inp)
         t=get_timer1();
         if (t>800) return 0;   // no RC5 code, abort decoding
      tmp<<=1;
      if (inp==0) tmp++;
      set_timer1(0);
      while (get_timer1()<776);  // a simple delay would work here as well
   tmp=tmp | 0x3000;
   tmp=tmp & 0x37ff; // cut off togglebit
   rc5.data[0]=tmp & 0xff;  // device address
   tmp>>=8;
   rc5.data[1]=tmp & 0xff;  // command code
   rc5.state = 1;
   disable_interrupts(INT_EXT);
   return 1;
void main()
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
   setup_timer_2(T2_DISABLED,0,1);
   enable_interrupts(INT_EXT);
   enable_interrupts(GLOBAL);
   rc5.state = 0;
   while(1)
      if(rc5.state==1)  // did we receive a valid RC5 - command?
         // interprete the command here...
         rc5.state = 0;
What issues you are facing with this program?
Let me know the issues than only we can understand.
Regards
Chanchal
I burn that program in the PIC18F252 and by using max232 i send the data to the PC but did not get any output at the hyper terminal. The remote send data to the IR and the IR is connected to the PIC PIN RBO and C6=Tx and C7=Rx.
I made some changes in this code and the new code is given below.
#include <18F252.h>
int1 get_RC5(void);
#define IR_INPUT PIN_B0            // the IR-Decoder has to be connected to an interrupt pin
#define IR_STATUS (!input(IR_INPUT))   // invert signal from IR-Receiver
typedef struct
int8 data[2];
int8 state;
rc5_struct;
rc5_struct rc5;
// interrupt function for external interrupt pin
#int_EXT
EXT_isr()
   get_RC5();
// RC5 decoding
int1 get_RC5(void)
   int16 tmp,t;
   int i;
   int1 inp;
   set_timer1(0);                      // reset timer
   t=get_timer1();
   if ((t<400) || (t<800)) return 0;   // no RC5 code, cancel decoding
// receive all 13 data bits
   for (i=0;i<13;i++)
      inp=IR_STATUS;
      set_timer1(0);
         t=get_timer1();
         if (t>800) return 0;      // timing wrong -> no RC5
      tmp<<=1;
      if (inp==0) tmp++;
      set_timer1(0);
   tmp=tmp | 0x3000;                  // clear Bits 13,14 & 15
   tmp=tmp & 0x37ff;                  // cut off Togglebit
   rc5.data[0]=tmp & 0xff;            // extract device address
   tmp>>=8;
   rc5.data[1]=tmp & 0xff;           // extract command code
   rc5.state = 1;                    // set flag for successful IR command decoding
   disable_interrupts(INT_EXT);      // disable Interrupts until received command has been processed
   return 1;
void main()
   // controller initialisieren
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);   // timer1 is used for RC5-decoding. When the chip runs @ 20MHz,
   // a prescaler of 8 has to be used
   //setup_comparator(NC_NC_NC_NC);
   //setup_vref(FALSE);
   // enable interrupts
   rc5.state = 0;
   while(1)
      if(rc5.state==1)
      // did we receive a valid command?
      printf("Device: %u\n", rc5.data[0]);     // display device address
      printf("Command: %u\n", rc5.data[1]);    // display command code
      rc5.state = 0;
      enable_interrupts(INT_EXT);   // reenable interrupts
Do you have a MAX232 or sth like that between PIC uC and a PC serial port?
Do you have an oscilloscope to check signals on uC pins, before PC serial port?
Before using the PIC I advise to work step by step.
1- Prepare you signal converter: Look for some schemtics on the net on how to use a max 232.
2- After powering your circuit do a loop at the TTL side of the max232 and use Hyperterminal to read and write characters.
3- If your circuits is ok and you could send and receive data, Swith off power, connect the PIC and switch on the power again.
4- Normally If your code is ok you should be able to communicate with the PIC, else, in you code check the baudrade, IO direction, pull up resistors etc.
The Site you have provided is not in English.
I don't understand what is written on that site.
