hiten09
Member level 2
i wanted to build a ir sensor module of 38khz, for that i m making the transmitter part through 555 ic and in receiver section i m using ir receiver ie. TSOP1738. but i am confused with the circuit diagram of transmitter.
i am confused whether the above circuit is correct or i found 2 3 more which are as follows..
i am confused which circuit is correct if anyone have the working circuit diagram please post it.
i also wnted to know the range of this ir module i mean how much far apart we can keep the transmitter and receiver
