zanor
Member level 4
Hi!
I'm trying to program this chip using PIC16F819. I have managed to read it but not erase/program or even getting right ID. I'm using three 74HC595 for adressing and PORTB for data #CE is wired directly to ground.
Datasheet for W29C020
ANY help/comments/suggestions would be great!!
I know there are severeal other programmers out on the net with ready pcb drawings and everything, but I want to do it the hard way. Make my own
Here is my code so far (using mikroC):
#define bit_set(var,bitno) ((var) |= 1 << (bitno))
#define bit_clr(var,bitno) ((var) &= ~(1 << (bitno)))
int DATA;
int x, y;
void clock() {
bit_set(PORTA, 3);
bit_clr(PORTA, 3);
void latch() {
bit_set(PORTA, 4);
bit_clr(PORTA, 4);
void send_adr(unsigned long int ADR){
clock();
for(x=0;x<24;x++) {
if((ADR >> x) & 0x1) {
bit_set(PORTA, 2);
clock();
bit_clr(PORTA, 2);
latch();
void read_byte(unsigned long int tmp) {
TRISB = 0xFF;
send_adr(tmp);
bit_clr(PORTA, 0);
Delay_ms(1);
data = PORTB;
bit_set(PORTA, 0);
void write_byte(unsigned long int tmp, int tmp2) {
TRISB = 0x00;
send_adr(0x5555);
bit_clr(PORTA, 1);
PORTB = 0xAA;
bit_set(PORTA, 1);
send_adr(0x2AAA);
bit_clr(PORTA, 1);
PORTB = 0x55;
bit_set(PORTA, 1);
send_adr(0x5555);
bit_clr(PORTA, 1);
PORTB = 0xA0;
bit_set(PORTA, 1);
send_adr(tmp);
bit_clr(PORTA, 1);
PORTB = tmp2;
bit_set(PORTA, 1);
read_byte(tmp);
while((DATA != tmp2) && ((DATA & 0x20) == 0)) {
read_byte(tmp);
read_byte(tmp);
if(DATA == tmp2)
Soft_Uart_Write(0xFF);
else
Soft_Uart_Write(0x44);
void erase_chip() {
TRISB = 0x00;
send_adr(0x5555);
PORTB = 0xAA;
bit_clr(PORTA, 1);
bit_set(PORTA, 1);
send_adr(0x2AAA);
PORTB = 0x55;
bit_clr(PORTA, 1);
bit_set(PORTA, 1);
send_adr(0x5555);
PORTB = 0x80;
bit_clr(PORTA, 1);
bit_set(PORTA, 1);
send_adr(0x5555);
PORTB = 0xAA;
bit_clr(PORTA, 1);
bit_set(PORTA, 1);
send_adr(0x2AAA);
PORTB = 0x55;
bit_clr(PORTA, 1);
bit_set(PORTA, 1);
send_adr(0x5555);
PORTB = 0x10;
bit_clr(PORTA, 1);
bit_set(PORTA, 1);
Delay_ms(50);
void main(){
OSCCON = 0xFF;
ADCON1 = 0x06;
TRISA = 0b00000000;
TRISB = 0b11111111;
PORTA = 0x03;
PORTB = 0x00;
Soft_Uart_Init(PORTA, 6, 7, 9600, 0);
Delay_ms(1000);
Soft_Uart_Write(0x01);
read_byte(0x145);
Soft_Uart_Write(data);
//write_byte(0x145, 0x23);
erase_chip();
read_byte(0x145);
