need help please... (ECG)
ranggaperdana_06114
Member level 3
ad624 ecg
hai bro i need help for this project.
i've find the design of ecg project from site :
https://www.picotech.com/applications/ecg.html
but i can't find the IC is AD624 but i found the AD620.by the way i don't know how to make it with AD620, can you tell me how to make this project with AD620 and what's diode that i must use cause i can't see the part number?
please help me...
tanx before...
D_A_V_E
Member level 5
please check this project
If you need any help please pm
D_A_V_E
Member level 5
try some 1n4148 but it should work without the diodes. They are for protection or better yet some SD101
ranggaperdana_06114
Member level 3
how if i want to filter the signal to make them so clear what i must use it
D_A_V_E
Member level 5
Just use a simple low pass and then filter digital in microcontroller.
akss_here
Member level 2
Bangalore
you need some clear signal..
the filter will extract noise and unwanted signal...
how this will work.. that is elementary questions,,
which need proper study...
HAPPY..:D
