Need help on project "PC based robot"
Krishna Patil
Shimoga, Karnataka, India
I'm making "PC based robot" from 8051 projects site.
PC Based Robot (AT89C2051)
I'm not getting desired output.
1) Relays always stays in one state when powered, even if i press keys in software. The software i used is "Without camera interface"
View attachment PC-Based-robot-exe-file (1).zip
2)I have used ULN2003A instead of ULN2003 . Is that a problem ?
**Relays are powered by 12V source and all other IC's by 7805(regulator).
3)ULN 2003 must stay at +5v at normal time and goes to 0v when activated.But it is not happening so , what might be the problem ?
4)I tried to compile project1.vbp but got a error that "videocap.ocx could not be loaded". Actually i don't have Wireless camera. I'll use my Phone's camera over bluetooth as wireless camera. So chose "without camera interface" software.
Here is picture of PCB i have made,
here I have only connected 16th pin of ULN to relay and checking its working when i press "FRONT" in software. If found working i'll buy four relays.
Please help me. I'm near to completion.I'll be waiting for response.
what os version ?
since it is based on com port ,
check your com port first.
is it com1 or com2 ? did you connect it correctly?
if it is com1 and working all right, then
send the commandcode from pc to 2051 , say , your init command etc.
check whether there is any response from 2051.
use hyperterminal .
send the code from terminal .
you will get some response.
I couldn't find hyperterminal in windows 7.
---------- Post added at 17:17 ---------- Previous post was at 17:05 ----------
Sincere thanks for your suggestion . I'll somehow find hyperterminal and try it .
win7 , i think , does not come with hyperterminal.
still you can google for one .
or use xp for such debugging.
