[SOLVED] need help on mosfet circuit
pona
Junior Member level 2
The control logic in fig1 generates a high(10v) or low(0v) signal to supply the gate of M2 to turn it off or on which will then turn M1 on or off. The mosfet M2 alone works fine with circuit shown in fig 2 but when I connect it with M1, M1 doesn’t turn on or off. What can be the problem? Do I need a driver circuit for M1?
  • Fig 1.doc
Please post the complete circuit with the power supply and load.
The way you have it now there is no resistor connected to the drain of M2 so it can only ground the gate of M1 or leave it floating.
You need a resistor like fig2 that goes from drain to the positive supply but it will not work if you want to use M1 as a high side switch, the gate has to have a higher voltage compared to the source of the mosfet.
Alex
Reactions: fshunj
    fshunj
If you try to use a Nmosfet as a high side switch and you drive the gate with the same voltage that you apply to the drain (or lower) then the mosfet will be in a half open state, depending on the gate threshold of the mosfet you will have an increased Vds voltage drop over the mosfet.
To use it correctly you have to apply to the gate a voltage that is higher then the drain, this happens because when the mosfet turns on the source voltage will be almost equal to the drain (for example 10v), if you have applied that same 10v to the gate then you suddenly have no Vgs bias and this creates the problem.
See the correct circuit when a higher voltage (or a second isolated voltage) is used:
Notice the voltage drop on the first circuit which is wrong and the second which is correct.
The voltage drop depends on the gate threshold , it is lower for IRL2203 that has a gate threshold of 1v and higher for IRF640 which has a gate threshold of about 3-4v
The only other solution is to use a Pmosfet as a high side switch, then you don't need a higher voltage for the gate.
Alex
Reactions: fshunj
    fshunj
yes,if you use a follower drive the load,and the gate voltage is lower then the drain ,the MOSFET is not completely on,than it will hot.So you also can ues a DC-DC source to drive the Gate.These problems are commonly seen in driving H-Bridge(if all are NMOS).
but if you put the load on the Drain,and the Source Grounding, it don't have this problem.
I sorry , my English is so poor:oops:.
I have attached the complete circuit. Load is a resistor of 5 ohms.
  • Doc1.doc
If your transistor turns on by a voltage of 10V at the gate then I hope this circuit will do the trick.
you need to use a resistor from the 10v to the gate of the output mosfet to be able to get some output but you will have the problem i have described above, high losses and voltage drop.
Unless you are able to drive the gate with a voltage at least 15v (5v above drain ) you can't use this circuit.
You either have to use a Pmosfet or you can use the output mosfet as a low side switch, providing gnd to a load that is connected to the positive power supply.
Alex
I have tried all these options of using two mosfets including pnos and low side nmos switch but none works. So now i'm trying to use a single high side nmos switch as shown. But still its not giving correct results. What can be the problem?
  • Docc1.doc
This is a circuit that works
but the point is for you to understand what you are doing in the circuit,
you have to use a resistor like R2 with provides positive supply to the gate when Q2 is of so that Q1 turns off too, if you don't use that resistor then the circuit can't work.
The mosfets were random models, you can use any models.
You can also use a NPN instead of mosfet Q2.
The voltages in the circuit show the on state when input is 5v,
I hope you are not switching in a fast rate because then you need higher current for the gate so that switching is fast.
Alex
I have already explained what is wrong with that in a previous post.
The Nmosfet turns on when you have a voltage applied to the gate that is higher than the source, you can't control your high side Nmosfet with 5v to the gate because as soon as it turn on you will have 10v in the source and then you have no bias so it turns off.
Alex
thanks alot alex for replying.
