yx.yang
Full Member level 4
- Joined
- May 29, 2008
- Messages
- 236
- Helped
- 49
- Reputation
- 98
- Reaction score
- 46
- Trophy points
- 1,308
- Location
- ZhuHai, GuangDong, China
- Activity points
- 2,661
[solved] Need help on mix different clocks' DFFs in one scan chain, has timing issue?
Hi, All:
I meet a problem about mixing different clock tree DFFs to one scan chain. I don't know whether this will causing timing issue for the DFFs at cross clock tree point (for exampel:data come from clk_tree_1 DFF and send to clk_tree_2 DFF).
As we using 90ns process now, we need consider the OCV iuuse, this cause even worse timing issue to the cross clock tree point. Becaue the two clock tree are totally different. Then the delay variation of the two clock tree will be a little big number under OCV analysis mode.
I see DC DFT user guide has said: dc_dft can insert a "lockup latche" at that point, while the DOC doesn't explaint this clearly.
Can anyone help me solve this problem or give me some info.
1): can we mix different clock tree DFFs in one scan chain or not? Consdier the OCV issue under 90nm process.
2): where can I find some more infos talking about this.
Thanks ahead.
Hi, All:
Thanks ahead.
