vvarlord
Member level 4
i wrote a code for an atmega8, for using as a clock which shows the time on a lcd ,and it can be set by an external interupt, and makes an output 1 at certain times,
the problem is that in intrupt mode, when i want to enter the clock, the column for digits of 1 , 4 , 7 &the zero digit , don't work
everything else is ok
i tried to change the ports , for inputs and outputs, but doesn't change a thing
This program was produced by the
CodeWizardAVR V2.05.3 Standard
Automatic Program Generator
© Copyright 1998-2011 Pavel Haiduc, HP InfoTech s.r.l.
[url]http://www.hpinfotech.com[/url]
Project :
Version :
Date : 10/31/2012
Author : PerTic@n
Company : If You Like This Software,Buy It
Comments:
Chip type : ATmega8L
Program type : Application
AVR Core Clock frequency: 8.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
#include <stdio.h>
#include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>
int M=0,H=0,x=0;
int a,b=0,c=0,d=0,e=0,y=0;
char S[40],T[40];
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
lcd_clear();
while(y<4)
while(1)
PORTD.0=0;
PORTC.3=1;
if(PIND.1==1)
{a=1;
PORTC=0;PORTD=0;break;}
if(PINC.1==1)
{a=2;
if(PINC.2==1)
{a=3;
PORTC.3=0;
PORTC.4=1 ;
if(PIND.1==1)
{a=4;
if(PINC.1==1)
{a=5;
if(PINC.2==1)
{a=6;
PORTC.4=0;
PORTC.5=1;
if(PIND.1==1)
{a=7;
if(PINC.1==1)
{a=8;
if(PINC.2==1)
{a=9;
PORTC.5=0;
PORTD.0=1;
if(PINC.1==1)
{a=0;
delay_ms(50);
if(y==0&&a<3)
b=a;
sprintf(T,"%d",b);
lcd_puts(T);
y=1;
else if(y==1&&b<2)
c=a;
sprintf(T,"%d",c);
lcd_puts(T);
lcd_puts(":");
y=2;
else if(y==1&&b==2&&a<4)
c=a;
sprintf(T,"%d",c);
lcd_puts(T);
lcd_puts(":");
y=2;
else if(y==2&&a<6)
d=a;
sprintf(T,"%d",d);
lcd_puts(T);
y=3;
else if(y==3)
e=a;
sprintf(T,"%d",e);
lcd_puts(T);
y=4;
y=0;
M=d*10+e;
H=b*10+c;// Place your code here
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
// Func6=In Func5=Out Func4=Out Func3=Out Func2=In Func1=In Func0=In
// State6=T State5=0 State4=0 State3=0 State2=T State1=T State0=T
PORTC=0x00;
DDRC=0x38;
// Port D initialization
// Func7=In Func6=Out Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=0 State5=T State4=T State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0x01;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Rising Edge
// INT1: Off
GICR|=0x40;
MCUCR=0x03;
GIFR=0x40;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
// Characters/line: 8
lcd_init(8);
// Global enable interrupts
#asm("sei")
while(1)
while(H<24)
while(M<60)
lcd_clear();
sprintf (S,"%d : %d",H,M);
lcd_puts(S);
if((H==7&&M==30)||(H==9&&M==0)||(H==9&&M==10)||(H==10&&M==40)||(H==10&&M==50)||(H==12&&M==20)||(H==12&&M==30)||(H==13&&M==15))
x=1;
PORTB.3=1;
delay_ms(2482);
PORTB.3=0;
if(x==0)
{delay_ms(7370);
if(x==1)
{delay_ms(4870);
x=0;
M=M+1;
H=H+1;
M=0;// Place your code here
H=0;
