Sep 15, 2019 #1 J jwonoh Newbie level 5 Joined Jul 31, 2019 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 98 Hi all I have a problem with balun simulation which is made by coilsys. as you can see bellow, 4 layout pins are connected to same net ( P_minus ) and I wanna force these pins to adequate nets respectively. How can I force them ..?
Sep 15, 2019 #2 BigBoss Advanced Member level 6 Joined Nov 17, 2001 Messages 5,950 Helped 1,609 Reputation 3,225 Reaction score 1,592 Trophy points 1,393 Location Türkiye Activity points 35,759 But they are physically connected, you wanna separate the nets ?? I don't think so that is possible..
Sep 15, 2019 #3 V volker@muehlhaus Advanced Member level 6 Joined Apr 11, 2014 Messages 3,184 Helped 1,068 Reputation 2,138 Reaction score 1,135 Trophy points 1,393 Activity points 20,229 Is the layout correct? Is there a connection between primary and secondary, possibly because of wrong layer assigments?
Sep 15, 2019 #4 BigBoss Advanced Member level 6 Joined Nov 17, 2001 Messages 5,950 Helped 1,609 Reputation 3,225 Reaction score 1,592 Trophy points 1,393 Location Türkiye Activity points 35,759 This is not a Balun, it's a transformer with tapped pins.It can be used as a Balun of course but tapped pins are not necessary if you don't drive an active circuit through them..
