abhi@eda
Member level 1
- Joined
- Mar 12, 2013
- Messages
- 41
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Bangalore
- Activity points
- 1,679
hi all,i came across Brushless DC motors today as saw they are rated in Kv
say like 500kv,that's 500 RPM per 1 DC voltage
assume a BLDC motor with these specs
Operating Voltage: 44.4V (12S lipoly)
RPM: 510kv
Max Current: 70A
Max Power: 3100W
Idle Current: 1.9A
Resistance: 0.024ohms
Shaft: 6mm
Connector: 4mm bullet
Bolt Hole Spacing: 25/30mm
Bolt Thread: M3
Weight: 362g
it says operating voltage is 44.4V,so at that voltage the motor should run at speed of 510 * 44.4v = 22,644 RPM
am i right about it?isnt that the MAX voltage for that motor?
it can also run with less voltage..
Say i want the motor to run at around 2000RPM ,so 4 vold DC would do, 4 * 510 = `2000RPM,do you think it would run with that low voltage?
also can you tell me at 4 volt how much current it would consume?
RPM: 510kv
Max Current: 70A
Max Power: 3100W
Idle Current: 1.9A
Shaft: 6mm
Bolt Thread: M3
Weight: 362g
