need help in these Flter Questions
vjfaisal
Full Member level 4
pakistan
firpmord ripple calculate dev
hi
i have got some problem here during designing of band pass filter
using optimal and kaiser(window).
The statement is from documents of kaiserord
Results are inaccurate if the cutoff frequencies are near 0 or the
Nyquist frequency, or if dev is large (greater than 10%).
Q1: what the DEV meant for? and what this (greater than 10%) means,
which causes to inaccurate the results
The statement from the kaiserord document in Matlab
You specify each entry in dev as a positive number, representing
absolute filter gain (not in decibels)
Q2: what does the satement try to tell? please expain in detail
best regards
Added after 11 minutes:
hi ,
here is the code for the equiripple filter
rp = 3; % Passband ripple
rs = 40; % Stopband ripple
fs = 2000; % Sampling frequency
f = [500 600]; % Cutoff frequencies
a = [1 0]; % Desired amplitudes
% Compute deviations
dev = [(10^(rp/20)-1)/(10^(rp/20)+1) 10^(-rs/20)]; <<<<<
[n,fo,ao,w] = firpmord(f,a,dev,fs);
b = firpm(n,fo,ao,w);
freqz(b,1,1024,fs);
title('Lowpass Filter Designed to Specifications');
Q1: As we already give a[1 0 ] ,showing our desired Amplitude (passband), then why in the firpmod , it could itself calculate the Amplitudes in ao.
Q2: why here both the stop and pass Ripples are divide for the desired Amplitude?
please help in these important concepts..
best regards
vjfaisal
Full Member level 4
pakistan
firpmord ripple dev
these are very helping qUESTION FOR FILTER DESIGN , sO PLEASE HELP ME ...
BEST REGARDS
