Need help in setting the fuse bits of atmega 8 .
Rohi231
Member level 2
Hello every1. I am new to AVR platform. I am using ponyprog and atmega 8.
I didnt set any fuse bits in ponyprog. I have seen in forum that if we wont set proper fuse bits it will damage the IC and it cannot be used for further use.
Can anyone tell me what are the fuse settings in atmega 8 without external crystal?
thanks in advance:arrow:
sherazi
Banned
Muscat, Oman, Oman
if you would be using the device with default fuse setting its going to work. if you change the fuses ,then it should properly be done. default fuse setting would be using 1Mhz internal oscilator, Jtag enabled etc if you are ok with it dont change the fuses
Rohi231
Member level 2
Thanks for the reply.
I am supposed to change the internal clock settings as 8 mhz. How to do it?
Please check the attachment.
nandhu015
Advanced Member level 5
India
Jtag enabled etc
There is no JTAG in ATMEGA8.
@Rohi123
Looking at the attachment fuse for internal 8MHz is correct.
Do you need bootloader which is selected for 1024 bytes in your attachment.
sherazi
Banned
Muscat, Oman, Oman
check this
for changing the clock to *mhz internal source just uncheck Clck DIV/8 fuse
Rohi231
Member level 2
Hello everyone. Thanks for the quick reply. I have programmed the atmega 32 and adjusted the security and configuration bits as attached. I am not able to display anything in uart. I have tried many uart programs but i am able to blink led. Please help:)
I am unable to do attach the file. I have done the configuration as in the below link.
http://www.petervis.com/C/1st%20configuring/ATMega32%2016Mhz%20Clock%20Fuse%20Bit%20Setting%20.html
sherazi
Banned
Muscat, Oman, Oman
share the code maybe there is some error in the code! do you get some unreadable data on terminal or nothing at all??
**broken link removed** .html
it gives 404 error
Rohi231
Member level 2
Sorry. This is the site which i refered for configuration settings.
Here is the attached code for serial communication .
Thanks in advance.
Now i am unable to program. Its coming write failed. Please help me on this.
I am getting nothing in the hyperterminal window.
  • serialport.zip
