need help in running led display
raman00084
Full Member level 6
can anyone help in running message display circuit(hard ware) and coding i want the cocept of the program
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
what kind of display.... how many display you will connect? what is the controller? what is the application.. if you dont tell your requirements then its difficult to help you.
vinoth8051
Full Member level 3
Delhi, Kanpur, Madurai, India
And add information on How characters you have to display, LCD or LED type. There are many ways for making "running message display". This possible even with digital gates, with out micro controller. Unless your requirements are clear, its difficult to help u.
raman00084
Full Member level 6
i like to use led the lengh of the display will be around 2 feet and breath will be 6 inches. the same display we see in bank that uses full led(dot matrix) . the controlleer will be atmel 8051 are pic 16f877a
---------- Post added at 06:54 ---------- Previous post was at 06:53 ----------
Embedded_Geek
Full Member level 6
Germany
Dont mention the size of display. Mention the no.of columns and rows of leds.
ckshivaram
i think it may be 5*7 matrix and 12 blocks of such kind....
number of blocks may not affect as you need shift registers for the same and give cloclk for shifting the data.... size does not matter
