Need Help in Matlab Simulink (SC Integrator Noise)
taik
Member level 3
Hi all, I come across this paper and would like to try it out on Simulink.
http://lib.tkk.fi/Books/2001/isbn9512263378/papers/1217.pdf
1) With regards to the block diagram, should I use the Discrete-Time Integrator from Simulink to represent Discrete Integrator in the block diagram?
2) How do I do a sweep of frequency since the block diagram is freq-dependent? Using the normal start in Simulink will only result in a time sweep.
Appreciate for any advice given.
Thank you in advance.
taik
Member level 3
anyone can help?
thanks...
