vjfaisal
Full Member level 4
hi ,
please help me in designing the simple filter :
The signal use to bandpass is in text form (EEG) data, is also uploded, and it needs
without using the FDA Tool. the given specification is given as:
Use the tool MATLAB simple coding
Q: sampling (hz): 200
cutoff1: 12 hz
cutoff2: 18 hz
use fir1 filter , and use no.of samples, at the best result.
please help me in this work ,as i want to compare my result, a si suspect i could be wronge....
please help me.... if anybody could.......
best regards
cutoff1: 12 hz
cutoff2: 18 hz
best regards
