need help in designing smps circuit for given specifications
Ramamurthi
Newbie level 2
bangalore
smps design
hi,
can any one help me out in designing a smps circuit for spcifications given below
input- 230volts 5 amps
requried output- 24volts dc with 4 amps
- 5volts dc with 2 amps
what are the things i need and if anyone can tell me where can i find the circuit diagram for this specifications:?:
Re: smps design
You are asking for an SMPS with less than 10% efficiency !
Are you sure about those specifications?
Brian.
Re: smps design
hi ,
Thanks for your response.
Yes i need smps circuit for these specification....
smps design
go for topswitch
hi anybody can helpme please ,currently i made a smps using the STR-6756W from sanken elec. i found hard to control my output voltage ,i wanted to have a variable output since it is a fixed design of 15volts.
